News
Showcase
E-Shop
Products
Vivid Unit: a Versatile Single-Board Computer with Touchscreen
PiGear Nano: Nano-ITX Raspberry Pi Compute Module 4 carrier board
Witty Pi 4: Realtime Clock and Power Management for Raspberry Pi
RasPiKey: Plug and Play eMMC Module for Raspberry Pi
Zero2Go Omini Rev2: Wide Input Range, Multi-Channel Power Supply for Raspberry Pi
MEGA4: 4-Port USB 3.1 PPPS Hub for Raspberry Pi 4B
BIG7: 7-Port MTT USB Hub for Raspberry Pi (Rev 2)
Zero4U 4-Port USB Hub Board Without Pogo Pins
MOSWITCH-SPDT: 9A / 28V Single Pole Double Throw MOSFET Switch
UUGear Solution: Raspberry Pi + Arduino
UUGear Web Interface (UWI)
Forum
About
About Us
Terms and Conditions
FAQ
Contact Us
Our Resellers / Distributors
My Account
News
Showcase
E-Shop
Products
Forum
About
About Us
FAQ
Contact Us
My Account
Home
Showcase
30
All
6
Arduino Related
4
Components
2
Kits
28
Raspberry Pi Related
1
Vivid Unit
Compile and Flash Firmware for Witty Pi 4
Tutorial
Install Home Assistant Supervised on Vivid Unit
Install Witty Pi 3 software on Ubuntu
Ubuntu
Access Raspberry Pi and UUGear Devices via Web Browser
IoT
How to Update Firmware for Witty Pi 3 / Zero2Go Omini
tutorial
Adding DC/DC Step-Up (Boost) Module to Witty Pi Mini
hack
Put Witty Pi Mini and Zero4U Together
tutorial
Make Your Zero2Go "Default ON"
hack
Is Zero4U Compatible with Raspberry Pi Zero W?
Q&A
When Zero2Go Meets Zero4U
tutorial
Use Witty Pi 2 to Build Solar Powered Time Lapse Camera
tutorial
Is Witty Pi Compatible with Raspberry Pi 3?
Q&A
Read DHT11/22 Temperature & Humidity Sensor from Raspberry Pi
tutorial
Use Schedule Script to Control Your Witty Pi
tutorial
Change the Pin that Used by Witty Pi
tutorial
Use Witty Pi to Make Repeatable Schedules for Auto Startup and Shutdown Your Raspberry Pi
tutorial
Assembly Guide: Acrylic Case for Witty Pi + Raspberry Pi
kit
A Single Script to Setup I2C on Your Raspberry Pi
trick
Create Object Radar with Ultrasound Distance Sensor
fun
Raspberry Pi Measures 0~5V Voltage via Arduino
creative
Bluetooth Communication between Raspberry Pi and Arduino
creative
Raspberry Pi reads DHT11 via Arduino
creative
Flashing the Raspberry Pi Compute Module eMMC under Mac OS
knowhow
Using light sensor module with Raspberry Pi
tutorial
Using 2.8” Touchscreen Display on Raspberry PI
new
Assembly Guide: Acrylic Case for UUGear USB Hub and Raspberry Pi
kit
DHT11 Humidity & Temperature Sensor Module
tutorial
High Speed 7-Port USB Hub for Raspberry Pi
new
Use Raspberry Pi to Create Obstacle Avoiding Robot Chassis
maker
Make a Crazy 25-Port USB Hub
fun
Join Waitlist
We will inform you when the product arrives in stock. Please leave your valid email address below.
Email me when available
