ADJUSTABLE DC-DC STEP-UP POWER MODULE 2A BOOST CONVERTER
3.54
(  3.07GBP  /  3.80USD  /  5.19CAD  )
A mini DC/DC step-up (boost) module that accepts 2~24V and outputs up to 26V/2A.
13 in stock (more can be backordered)
SKU: ADJUSTABLE_DCDC_2A Category:
Tags: , , ,
Description
This is a mini DC/DC step-up (boost) converter module. It accepts 2~24V and outputs up to 26V/2A. It has a micro USB connector on board, and you can easily connect DC 5V as input power source.
Note: if you find the output voltage equals to the input voltage, please use a small screw driver to adjust the potentiometer clock-wise, for about 20 circles.
Specification:
  • Input Voltage Range: 2 ~ 24V DC
  • Output Voltage Range: Vin ~ 26V
  • Maximum Output Current: 2A (recommend 1A for long-term usage)
  • Efficiency: 93% max
  • Dimension: 30mm x 17mm x 6.5mm
Additional information
Dimensions 3 × 1.7 × 0.65 cm
Be the first to review “ADJUSTABLE DC-DC STEP-UP POWER MODULE 2A BOOST CONVERTER”
