[Mark Solved / Archieved] Building special linux image for Vivid unit
3 Reactions
(@houssem)
I'm looking to build an OS image lite without chrome and all the other apps, without the bottom Linux bar, the unit will be only running one app that I developed and I want to include it in the OS and the app auto start just after boot. Is there any tutorial for this ?
Looking at the vivid bsp release on github, I can download and build an OS, but it's containing both buildroot and yocto which confused me. why there is both of them, while I think they both do the same think?
thanks
Posted : 20/09/2024 3:37 pm
emdev reacted
We will not provide tutorial or technical support on such specific use case. I can however give some advices on how to do it.
What you need is basically an OS with a full-screen application automatically run on boot. This can be done without building the entire OS: the default OS can be customized to exactly that. The default OS uses XFCE 4 as the desktop enviroment, you may search how to hide its taskbar. Actually you don't even have to do that: if you make your applicatiopn full-screen and disable the three sense buttons on the right, there is no way to bring the desktop to top without connecting a keyboard and using system hotkeys. You may search how to make application full-screen, and how to make it automatically run on boot.
If you want to distribute your modified system, you may pack your whole customized system as a disk image, which can be used as the rootfs image when building the system.
Posted : 20/09/2024 4:01 pm
(@emdev)
Did you get this sorted out? I just received my unit and aiming to same with buildroot.
Posted : 08/05/2025 5:20 pm
(@emdev)
It took four weeks, but here is my buildroot image repository for Vivid Unit:
https://codeberg.org/resiliencetheatre/vivid-ext-tree
It runs latest mainline uboot and kernel and contains small lvgl demo application. Hope this helps others who are looking Vivid Unit as up to date platform for their custom designs with small and efficient Linux image, rather than bloated EOL distro.
Posted : 13/06/2025 5:46 am
