[Mark Solved / Archieved] Capacitor for input
 NF5
(@nf5)
I have a raspberry pi 4b with the witty pi 4. The power is supplied by the connector attached directly to motorcycle’s harness while driving sometimes when you slow down or sometimes when you shift  the voltage dips for a mili second not long enough for the witty to catch the voltage in the logs. What I need to know is what size capacitor I should use on the input to take care of that voltage drop
Posted : 09/01/2024 2:00 am
You will need to decide the value with experiments, because the actual powering enviroment is unknown to us (and to others).
Posted : 10/01/2024 9:24 am
