[Mark Solved / Archieved] Minimum Vin for Witty Pi 4 L3V7
Connecting a USB Power Bank runs my device no problem.
I have now tried to connect 2 usb power banks in series.  But every now and then the UPS will shutdown my RPi. Checking the logs I see it has shutdown because the Vin is too low.  As I understand it the UPS has a stepup. So my question is what is the lowest Vin that can be used and is there a setting to adjust it safely?
Posted : 29/01/2024 11:07 pm
How do you connect 2 USB power banks in serial? There is only one USB-C connector on the board.
Posted by: @andrew-simpson17
Posted : 30/01/2024 9:00 am
