[Mark Solved / Archieved] PiGear Nano: Unable to get pictures from the HQ Camera Module
 Dany
(@dany)
Hi there,
I followed the user manual ( https://www.uugear.com/doc/PiGearNano_UserManual.pdf) to setup my PiGear Nano.
I've installed the normal Raspberry PI OS (64-bit)
After the installation, I was setting up the CSI Camera Connector:
 > sudo cp pgnano/bin/dt-blob.bin /boot/dt-blob.bin
 > sudo chown root:root /boot/dt-blob.bin
 > sudo chmod 755 /boot/dt-blob.bin
After the reboot, I wanted to check the camera:
 > libcamera-hello --list-cameras
It was showing me the camera, so the camera is detected.
By running the
 > libcamera-hello
I got the following errors:
ERROR RPI pipeline_base.cpp:1333 Camera frontend has timed out!
ERROR RPI pipeline_base.cpp:1334 Please check that your camera sensor connector is attached securely.
ERROR RPI pipeline_base.cpp:1335 Alternatively, try another cable and/or sensor.
I was using the camera on another raspberry pi and it worked, so the camera must be fine.
I've also used another cable for this one, so I guess the cables are also fine. The camera is also detected, so the cables should be fine.
My model:
 > cat /sys/firmware/devicetree/base/model
Returns: Raspberry Pi Compute Module 4 Rev 1.0
Have you got any ideas how to solve the problems?
Best regards
Posted : 29/08/2023 4:13 pm
Have not seen these errors before, but searching those error messages leads me to this page:
https://github.com/raspberrypi/picamera2/issues/748
Someone wrote that he fixed it by running "apt install libcamera-apps", which looks promising.
Posted : 29/08/2023 6:23 pm
 Dany
(@dany)
I have got the newest version of libcamera-apps.
I've tried uninstalling and installing it again but it didn't help.
In the raspi-config I should see the Camera in the Interface Options, but there is nothing.
The camera is shown with the command "libcamera-hello --list-cameras".
The issue on github didn't help me. Have you got any other ideas?
Posted : 30/08/2023 2:05 pm
