[Solved / Archived] Raspberry Pi is not booting with RasPiKey
 hoiz
(@hoiz)
Hello support,
I have now tried the RasPiKey with a Raspberry Pi 3 Model B and a Zero 2 W and it just won't boot.
This is what I did: I did not use the RasPiKey with the original image, but reflashed it directly with the Raspberry Pi Imager (on macOS) because I wanted to install Home Assistant OS. After plugging it in and powering it up, the Raspberry Pi 3 Model B didn't show any activity.
Then I flashed it with the original image ( https://www.uugear.com/repo/RasPiKey/RasPiKey.img) but that didn't work in the 3 Model B or the Zero 2 W either.
What am I doing wrong here? What else can I try?
Thank you very much!
Stephan
Posted : 18/07/2024 1:14 pm
Can not tell the reason why it doesn't work.
Since you are using Macos, you may try flashing it with dd command -- this is the way we provisioned it.
Posted : 18/07/2024 1:51 pm
