[Mark Solved / Archieved] Raspberry Pi Zero 2W with Zero2Go Omini does not retain Default State setting after power loss
(@jcharrington)
I am having an issue using a Zero2Go Omini with a RPi Zero 2W.  For some reason, the Omini is not retaining the "Default State" setting after power loss, so I can not use it to boot the RPi Zero 2W after power loss without having to push the power button on the Omini.  I have tried setting the "Default State" using the zero2go.sh script as well as using i2cwrite directly.  Looking at the firmware, it appears that this setting should be saved/loaded to EEPROM.  The Omini seems to be functioning properly otherwise.
Are there any further troubleshooting steps I can perform?
V/R
John
Posted : 26/10/2023 12:15 pm
This setting is indeed saved to EEPROM. There are other configurations (such as low-voltage threshold, recovery voltage, LED blinking interval etc.), and they are all saved in EEPROM. Do those configurations retain after power loss?
Posted : 30/10/2023 8:13 am
