[Mark Solved / Archieved] Unstable register reads with Arducam Mega
(@neunz)
I have a witty Pi 4 connected on a Raspberry Pi 3 B+ and an Arducam Mega 3MP.
The Arducam Mega use the following pins :
GPIO-22 -> Chip Select
GPIO-10 -> MOSI
GPIO-9 -> MISO
GPIO-11 -> SCK
VCC 3,3V and GND
Everything is powered with an AC-DC adaptor (Output 12Vdc at 2.08A).
If I don't connect the camera the program WittyPi.sh get the following (right) values :
>>> Current temperature: 28.5°C / 83.3°F
>>> Your system time is: 2024-12-09 17:05:47 GMT
>>> Your RTC time is: 2024-12-09 17:05:49 GMT
>>> Vin=13.19V, Vout=5.01V, Iout=0.66A
Now you can:
1. Write system time to RTC
2. Write RTC time to system
4. Schedule next shutdown [09 13:11:30]
5. Schedule next startup [09 13:12:00]
6. Choose schedule script
7. Set low voltage threshold
8. Set recovery voltage threshold
9. Set over temperature action
10. Set below temperature action
11. View/change other settings...
12. Reset data...
13. Exit
What do you want to do? (1~13)
Please choose from 1 to 13
As soon as I connect the camera I get unstable and wrong values as below :
>>> Your system time is: 2024-12-09 17:04:39 GMT
>>> Your RTC time is: 2012-12-09 17:04:41 GMT
>>> Vin=6.19V, Vout=4.95V, Iout=0.51A
Now you can:
4. Schedule next shutdown [04 13:11:18]
5. Schedule next startup [04 13:09:00]
8. Set recovery voltage threshold [12.7V]
12. Reset data...
13. Exit
>>> Current temperature: 28.375°C / 83.075°F
>>> Your system time is: 2024-12-09 17:04:40 GMT
>>> Your RTC time is: 2012-12-04 11:04:42 GMT
>>> Vin=6.19V, Vout=2.00V, Iout=0.58A
Now you can:
4. Schedule next shutdown [09 09:11:18]
5. Schedule next startup [09 09:12:00]
7. Set low voltage threshold [12.7V]
12. Reset data...
13. Exit
>>> Your RTC time is: 2024-12-09 11:04:43 GMT
>>> Vout=5.02V, Iout=0.24A
Now you can:
4. Schedule next shutdown [09 09:08:18]
12. Reset data...
13. Exit
>>> Your system time is: 2024-12-09 17:04:41 GMT
>>> Your RTC time is: 2024-12-04 17:04:44 GMT
>>> Vin=13.19V, Vout=2.01V, Iout=0.53A
Now you can:
4. Schedule next shutdown [04 13:11:30]
12. Reset data...
13. Exit
>>> Your system time is: 2024-12-09 17:04:42 GMT
>>> Your RTC time is: 2024-12-09 11:04:44 GMT
>>> Vout=2.01V, Iout=0.30A
Now you can:
5. Schedule next startup [09 13:09:00]
12. Reset data...
13. Exit
This behavior stay until the next reboot even if I remove de camera.
Sometimes after aproximately 50 reboots, my schedule is not respected and the raspberry pi shutdown but the witty pi never cut the power and I think this can be the cause.
What's very strange is that if I request the value by hand (for example the next startup day) I always get the same value as if there is no problem.
i2cget -y 1 8 30
0x09
Any idea about what's causing this strange behavior ?
Posted : 09/12/2024 7:53 pm
It seems some bytes were transferred incorrectly via I2C, but I can not tell the reason.
It is even mode difficult to explain, if you confirm the Arducam Mega 3MP doesn't use I2C at all.
Removing the camera doesn't immediately fix the issue, while a reboot does, that seems implying the problem was in the Pi's I2C stack.
Posted : 10/12/2024 11:37 am
(@neunz)
If I run the following script I start to see I2C read error after the 4th time.
max=1000
first_read=`i2cget -y 1 8 0`
false_count=0
for i in `seq 1 $max`
do
    r=`i2cget -y 1 8 0`
    if (($r != $first_read))
    then
	false_count=$((false_count + 1))
    fi
done
echo $false_count
Errors seems to increase over time up to 30%.
But I can't find a significant change with the arducam, I have these errors even without the arducam...
Do you have the same results ?
I will check if it's on the raspberry pi side or the witty pi side.
I already changed to a new raspberry just in case.
This post was modified 2 years ago by Neunz
Posted : 10/12/2024 4:57 pm
(@neunz)
I switched for a Rapsberry Pi 4 and I have no errors.
Maybe there is an issue with the Raspberry Pi 3.
Posted : 11/12/2024 11:30 am
