[Mark Solved / Archieved] Vivid Unit - No sound
(@mrtlikesrobots)
I just got a vivid unit and its up and running.   I'm unable to hear any sound out of the speaker or headphone jack regardless of the settings.  If I play a video on youtube I can see the sound in the mixer but I don't hear any audio.  I've tried various profiles in the configuration tab of the volume control but it hasn't had any effect.  I've also tried different sets of headphones that I know are working including 2 and 3 prong earbuds.  Any ideas?
Posted : 12/04/2024 1:08 am
Have you flashed OS image by yourself? Or you are using the default OS comes with the device?
Posted : 12/04/2024 8:39 am
(@mrtlikesrobots)
I was using the default OS.   I reflashed it and it seems to be working now.
Posted : 13/04/2024 1:40 am
@mrtlikesrobots There is a known issue in the OS with Home Assistant Supervised pre-installed. The sound device is occupied by hassio audio container, and the solution is to install this add-on.
However the default OS comes with the device should not have such problem.
Posted : 13/04/2024 8:22 am
