Vivid Unit POE
(@simon-cleveland)
I'm trying to power my Vivid Unit from a POE switch, and it does not seem to turn on.  The yellow light on the rJ45 port blinks yellow
I'm using a ubiquiti USW Lite 8 PoE sich is POE & POE+ capable.
Is this a faulty board?
Posted : 31/10/2024 4:52 pm
I don't know about that specific PoE switch, but every unit's PoE has been tested before being packed.
In the picutre below you can see its PoE wiring.
Posted : 31/10/2024 5:02 pm
(@simon-cleveland)
Which POE variants are compatible with the vivid unit? Does it only work with passive POE?
My switches provides 802.3AF POE and 803.AT POE+
I've not had success powering my vivid unit via POE trying multiple switches and multiple cables.
I just get a blinking light.
This post was modified 5 months ago by Simon Cleveland
Posted : 08/11/2024 10:31 pm
@simon-cleveland Vivid Unit uses the MP8001 chip, which supports 802.3af.
Posted : 09/11/2024 9:44 am
(@simon-cleveland)
Any troubleshooting resources as to why I can't power my unit via POE then?
Here is a short clip of what happens when I attempt to power via POE.  The power button remains unresponsive https://imgur.com/DCcmHCg
Here is what my POE tester says about the incoming connection https://imgur.com/BnhqzpZ
The unit works fine powered via USBC
Posted : 11/11/2024 1:42 pm
@simon-cleveland
I can see 3 results on your PoE tester. Does it say PoE (802.3af) and PoE+(802.3at) tests passed, while Passive PoE test failed?
I just tested again using a Mercury MS05CP PoE switch and it works well with Vivid Unit.
The PoE checker shows that it uses wire 1,2 and 3,6 for powering. I believe it is the "Alternative A" in 802.3af.
I also tested it with the PoE socket in my office, which shows 4 pairs mode and also works well, but I don't know which model of PoE switch is behind.
Posted : 11/11/2024 2:59 pm
