[Mark Solved / Archieved] Witty Board not connected
(@grbtxtmsg)
My Witty Pi Mini is not seeing my Raspberry Pi Zero 2w. After entering "sudo ./wittyPi.sh" I get the message: "Seems Witty Pi board is not connected?"
It is connected on (red LED on) and powered directly by its USB connector.  I ran the installer with admin privileges (sudo).
I have Witty Version 2.67 and Raspbian Version 10 (buster)
FYI: (Had it working earlier somehow but kept getting 5AM as Startup time when using a schedule file - so reinstalled.  Also power did not switch on specified times. I did a sync of clocks)
Log file attached.
[2019-02-14 02:12:05] Witty Pi daemon (v2.67) is started.
[2019-02-14 02:12:05] Running on Raspberry Pi Zero 2 W Rev 1.0
[2019-02-14 02:12:05] Wiring Pi version: 2.50
[2019-02-14 02:12:07] Witty Pi is not connected, skip I2C communications...
[2019-02-14 02:12:07] Witty Pi is not connected, skip synchronizing time...
[2019-02-14 02:12:10] Witty Pi is not connected, skip schedule script...
[2019-02-14 02:12:15] Pending for incoming shutdown command...
[2019-02-14 02:12:04] Witty Pi daemon (v2.67) is started.
[2019-02-14 02:12:04] Running on Raspberry Pi Zero 2 W Rev 1.0
[2019-02-14 02:12:04] Wiring Pi version: 2.50
[2019-02-14 02:12:06] Witty Pi is not connected, skip I2C communications...
[2019-02-14 02:12:06] Witty Pi is not connected, skip synchronizing time...
[2019-02-14 02:12:09] Witty Pi is not connected, skip schedule script...
[2019-02-14 02:12:14] Pending for incoming shutdown command...
[2019-02-14 02:13:07] Seems Witty Pi board is not connected? Quitting...
[2019-02-14 02:19:54] Seems Witty Pi board is not connected? Quitting...
Ron
This topic was modified 3 years ago 2 times by grbtxtmsg
Posted : 11/06/2023 8:29 pm
Witty Pi's software detects Witty Pi hardware by checking the I2C bus.
What is the output when you run command "i2cdetect -y 1"?
You didn't mention the version of your Witty Pi Mini board. If it is a Witty Pi 4 Mini, you need to use software version 4.00+
Posted : 12/06/2023 12:38 pm
(@grbtxtmsg)
The command i2cdetect -y 1 gives and 2d array - along the top : 0 to f and row headers: 00 to 70.  All values inside are '--' except at row 00 col 8 is '08'.
The version of Witty board is "Witty Pi 4 mini".
Posted : 12/06/2023 5:37 pm
So you are using the wrong version of software, which is for Witty Pi 3 (Mini). You may rename/remove the wittypi directory and then run these two commands in home directory:
wget https://www.uugear.com/repo/WittyPi4/install.sh
sudo sh install.sh
This will install the software for Witty Pi 4 (Mini).
Posted : 12/06/2023 5:55 pm
(@grbtxtmsg)
Getting Errors:
pi@raspberrypi:~ $ sudo sh install.sh
|                   Witty Pi Software Installation Script                      |
>>> Enable I2C
Seems i2c-bcm2708 module already exists, skip this step.
Seems i2c-dev module already exists, skip this step.
Seems i2c1 parameter already set, skip this step.
Seems i2c_arm parameter already set, skip this step.
Seems setting Pi3 Bluetooth to use mini-UART is done already, skip this step.
Seems setting Bluetooth to use mini-UART is done already, skip this step.
Seems the frequency of GPU processor core is set to 250MHz already, skip this step.
>>> Install i2c-tools
Seems i2c-tools is installed already, skip this step.
>>> Make sure en_GB.UTF-8 locale is installed
Seems en_GB.UTF-8 locale has been installed, skip this step.
>>> Install wittypi
--2019-02-14 03:35:03--  https://www.uugear.com/repo/WittyPi4/LATEST
Resolving www.uugear.com (www.uugear.com)... 172.104.156.161
Connecting to www.uugear.com (www.uugear.com)|172.104.156.161|:443... connected.
ERROR: The certificate of ‘www.uugear.com’ is not trusted.
ERROR: The certificate of ‘www.uugear.com’ is not yet activated.
The certificate has not yet been activated
Archive:  wittyPi.zip
  End-of-central-directory signature not found.  Either this file is not
  a zipfile, or it constitutes one disk of a multi-part archive.  In the
  latter case the central directory and zipfile comment will be found on
  the last disk(s) of this archive.
unzip:  cannot find zipfile directory in one of wittyPi.zip or
        wittyPi.zip.zip, and cannot find wittyPi.zip.ZIP, period.
install.sh: line 122: cd: wittypi: No such file or directory
chmod: cannot access 'wittyPi.sh': No such file or directory
chmod: cannot access 'daemon.sh': No such file or directory
chmod: cannot access 'runScript.sh': No such file or directory
chmod: cannot access 'beforeScript.sh': No such file or directory
chmod: cannot access 'afterStartup.sh': No such file or directory
chmod: cannot access 'beforeShutdown.sh': No such file or directory
sed: can't read init.sh: No such file or directory
chown: cannot access 'wittypi': No such file or directory
rm: cannot remove 'wittyPi.zip': No such file or directory
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
  0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0
curl: (60) SSL certificate problem: certificate is not yet valid
More details here: https://curl.haxx.se/docs/sslcerts.html
curl failed to verify the legitimacy of the server and therefore could not
establish a secure connection to it. To learn more about this situation and
how to fix it, please visit the web page mentioned above.
>>> Something went wrong. Please check the messages above 🙁
Posted : 12/06/2023 7:05 pm
If you check the error messages, you will find the problem actually comes from the system time on your Raspberry Pi:
Posted by: @grbtxtmsg
The time is still in year 2019, when the current certificate for our website was not activated yet (it gets renewed for every two months I think).
Setting a correct time to your Raspberry Pi should fix this problem.
Posted : 13/06/2023 8:31 am
(@grbtxtmsg)
Ok.  All works now.  Thanks very much.
Posted : 14/06/2023 4:05 pm
