[Solved / Archived] Witty Pi 4 L3V7 red LED stays on
 spel
(@spel)
I am very satisfied with the Witty Pi 4 L3V7. However, I have now noticed that after pressing the shutdown button again, the red LED stays on.
A long 10 second press of the button then switches off the red LED.
is this known?
Posted : 10/05/2024 8:57 pm
 spel
(@spel)
the power cut delay was too short... increased the seconds, and now everything works.
Posted : 10/05/2024 11:37 pm
@spel the delay of power cut should not cause the issue you previously mentioned. It is worth to check if the software has been properly installed. You may also want to look into the wittyPi.log file in the directory that has software installed.
Posted : 11/05/2024 9:38 am
