[Mark Solved / Archieved] Witty Pi 4 Low Voltage Shutdown
(@msage)
Trusted Member
Bit of a weird problem here, my pi 4 has started shutting down with a low voltage error. I have reset the low voltage information in the wittypi menu, and manually set it to disabled, however my pi 4 is still shutting down with a low voltage issue. The only way I can get it to boot is to remove the witty pi, reboot, disable the witty pi service, then reconnect the wittypi and boot. I then reset all the voltage menu options, but it is still shutting down with a low voltage error. Is there any thing else I can do? If I disable the witty pi service will scheduled start up and shutdown still work?
Posted : 11/03/2024 4:48 pm
How do you power your Witty Pi 4 + RPi 4?
If Witty Pi 4 shuts down your Pi due to low power, its software will write in the log like "Shutting down system because input voltge is too low...", have you saw this message in the log?
If you are powering your Witty Pi + RPi4 via the XH2.54 connector, and the voltage you feed to Witty Pi is too low, your Pi will still be off (ungracefully) even if you have not configured the low-voltage threshold, and you won't see anything in the log.
Posted : 11/03/2024 5:58 pm
(@msage)
Trusted Member
@admin I'm powering it using the official pi power supply, I've tried two adapters and POE. I get the error hwmon undervoltage detected then it shuts down, so it looks like it's graceful. If I disable the witty pi service then the pi seems to be ok.
Posted : 12/03/2024 12:43 pm
(@msage)
Trusted Member
Just put a multimeter on it, I'm getting 5.27v on the witty pi when powered off and over 5v when the pi is powered on, so I don't think power is the issue?
Posted : 12/03/2024 12:46 pm
(@msage)
Trusted Member
I think the undervoltage might be a "false flag", just looking through the log:
[xxxx-xx-xx xx:xx:xx] Witty Pi daemon (v4.14) is started.
[xxxx-xx-xx xx:xx:xx] Running on Raspberry Pi 4 Model B Rev 1.4
[2024-03-12 10:45:49] Done 🙂
[2024-03-12 10:45:49] Firmware ID: 0x26
[2024-03-12 10:45:49] Firmware Revison: 0x01
[2024-03-12 10:45:49] Current Vout=5.07V, Iout=1.74A
[2024-03-12 10:45:49] System starts up because the button is clicked.
[2024-03-12 10:45:54] Send out the SYS_UP signal via GPIO-17 pin.
[2024-03-12 10:45:54] Pending for incoming shutdown command...
[2024-03-12 10:45:55] Schedule next shutdown at: 2024-03-12 17:30:00
[2024-03-12 10:45:55] Schedule next startup at: 2024-03-13 05:30:00
[2024-03-12 10:45:55] Shutting down system because button is clicked or GPIO-4 is pulled down.
[2024-03-12 10:45:55] Halting all processes and then shutdown Raspberry Pi...
Other than updates I haven't changed anything on the pi, I definitely didn't press the button, so what could pull down GPIO-4?
Posted : 12/03/2024 12:56 pm
@msage the log you provided doesn't mention anything about undervoltage. It said the GPIO-4 was pulled down.
Besides human can press the button to pull down GPIO-4, Witty Pi's firmeware may pull down GPIO-4 to emulate button tapping when:
  • Scheduled startup/shutdown is due
  • In voltage is lower than predefined threshold
  • Over-temperature or under-temperature is triggered
For each situation, Witty Pi's firmware write the reason code to the register #11 (I2C_ACTION_REASON), which will be checked after the software detected GPIO-4 has been pulled down.
With that said, if the log says "Shutting down system because button is clicked or GPIO-4 is pulled down", it means:
  • GPIO-4 indeed has been pulled down (otherwise you would not see that line in the log)
  • Witty Pi's firmware didn't pull down GPIO-4 (otherwise the reason code will be different)
So, it seems either there was other hardware that pull down GPIO-4, or there was strong electromagnetic interference that triggered GPIO-4.
Posted : 12/03/2024 2:33 pm
(@msage)
Trusted Member
@admin Very, very strange, nothing has changed in my setup and it's been working for months! (other than the bookworm issue). Perhaps I've damaged my witty somehow 🙁
Posted : 12/03/2024 2:57 pm
(@msage)
Trusted Member
I've just tried it with my witty pi 4 mini that I had spare and it's showing the same problem. Any idea what troubleshooting I could try? I've tried with different power supplies (in case of electromagnetic interference). There is no other hardware other than the pi itself... Could any update have caused it?
This post was modified 2 years ago by msage
Posted : 12/03/2024 3:55 pm
(@msage)
Trusted Member
Just to add the pi doesn't shut itself down if the witty pi is removed
Posted : 12/03/2024 4:01 pm
What happened when you run "sudo shutdown -h now"?
Posted by: @msage
Posted : 12/03/2024 5:30 pm
(@msage)
Trusted Member
It shutsdown as expected 🙂
Posted : 13/03/2024 9:40 am
(@msage)
Trusted Member
I've done some more troubleshooting. I've tried a new bookworm install on a new SD card, I've tried a different pi 4 and the same behaviour is exhibited from the witty pi 4 and witty pi 4 mini 🙁
Posted : 13/03/2024 12:35 pm
Do you think it is possible that the MCU (ATtiny841) on your Witty Pi gets reset, and that voltage spike causes the GPIO-4 "pulled down"?  The thoughts come from this topic.
Posted : 13/03/2024 12:40 pm
(@msage)
Trusted Member
@admin Maybe, but I don't know what would cause it. Would this be an issue for witty pi 4 and the pi 4 mini? As I am seeing the issue with both. EDIT: I've read through the threads and the witty pi 4 (full size) shouldn't be experiencing this issue?
Posted : 13/03/2024 12:49 pm
If the enviroment has electromagnetic interference, it could be the case. All Witty Pi boards rely on the internal pull-up resistor and spike filter on the reset pin of ATtiny841, which seems not enough under certain circumstances.
Posted : 13/03/2024 12:55 pm
Page 1 / 2
