[Solved / Archived] Witty Pi 4 Mini - MOSI and SCLK access
(@dcr89324)
I am looking to use the Adafruit TLC59711 PWM led board ( https://cdn-shop.adafruit.com/datasheets/tlc59711.pdf) with a Witty Pi 4 mini on a raspberry pi zero 2w. To connect the board, I need access to the MOSI (physical pin 19) and SCLK (physical pin 23) pins which I see are available on the ICSP header (P4).  Is it okay to use the pins on P4 to connect to this board?  Thank you.
Posted : 28/07/2023 2:50 am
Please check page 44 in the user manual.
Those pins you mentioned are not used by Witty Pi.
Posted : 28/07/2023 11:06 am
(@dcr89324)
Thanks for your quick response, I appreciate it.
Posted : 28/07/2023 2:20 pm
