[Solved / Archived] Witty Pi 4 mini - Raspberry Pi - USB-C and SBU
(@azanger)
I'm relatively new to this space so apologies if this has an obvious answer.
I'm using a usb battery pack (voltaic v75) where one is able to read the cell voltage by comparing the voltage on the USB-C's SBU1/2 Pins to ground. My question is, would the witty pi 4 mini be able to read the SBU pins or would it require a usbc breakout board.
Thank you
Posted : 09/02/2025 7:34 pm
Unfortunately Witty Pi 4 (Standard, Mini or L3V7) doesn't read any SBU pin in USB-C connector.
Posted : 10/02/2025 8:08 am
