I have a Witty Pi 4 running on Raspberry Pi 5. I is suppose to start every 7m and after the job is done it will shutdown by itself.
With this script it is jumping 1 startup schedule and is starting the Raspberry every 15m like you can see in the logs below.
schedule.wpi
BEGIN 2025-03-24 07:52:30 END 2050-12-31 23:59:59 ON S30 WAIT OFF M7
schedule.log
--------------- 2025-03-27 13:00:41 --------------- Skip scheduling next shutdown, which should be done externally. Schedule next startup at: 2025-03-27 13:15:00 --------------------------------------------------- --------------- 2025-03-27 13:15:41 --------------- Skip scheduling next shutdown, which should be done externally. Schedule next startup at: 2025-03-27 13:30:00 --------------------------------------------------- --------------- 2025-03-27 13:30:41 --------------- Skip scheduling next shutdown, which should be done externally. Schedule next startup at: 2025-03-27 13:45:00 --------------------------------------------------- --------------- 2025-03-27 13:45:41 --------------- Skip scheduling next shutdown, which should be done externally. Schedule next startup at: 2025-03-27 14:00:00 --------------------------------------------------- --------------- 2025-03-27 14:00:41 --------------- Skip scheduling next shutdown, which should be done externally. Schedule next startup at: 2025-03-27 14:15:00 --------------------------------------------------- --------------- 2025-03-27 14:15:41 --------------- Skip scheduling next shutdown, which should be done externally. Schedule next startup at: 2025-03-27 14:30:00 ---------------------------------------------------
wittyPi.log
[2025-03-27 13:30:41] Skip scheduling next shutdown, which should be done externally. [2025-03-27 13:30:41] Schedule next startup at: 2025-03-27 13:45:00 [2025-03-27 13:30:41] Pending for incoming shutdown command... ... [2025-03-27 13:45:41] Skip scheduling next shutdown, which should be done externally. [2025-03-27 13:45:41] Schedule next startup at: 2025-03-27 14:00:00 [2025-03-27 13:45:41] Pending for incoming shutdown command... ... [2025-03-27 14:00:41] Skip scheduling next shutdown, which should be done externally. [2025-03-27 14:00:41] Schedule next startup at: 2025-03-27 14:15:00 [2025-03-27 14:00:41] Pending for incoming shutdown command... ... [2025-03-27 14:15:41] Skip scheduling next shutdown, which should be done externally. [2025-03-27 14:15:41] Schedule next startup at: 2025-03-27 14:30:00 [2025-03-27 14:15:41] Pending for incoming shutdown command...
Any ideas of whats wrong?
Posted : 27/03/2025 4:22 pm
This is called "shifting ON state", please search "shifting ON state" in the user manual to understand why it happens.
Posted : 27/03/2025 4:30 pm
