[Mark Solved / Archieved] WittyPi 4 Mini - Last action button vs power restore.
(@marcot77)
Hi. I'm reading the register 11 to act differently at boot between a scheduled boot and the button press. I have set the WittyPi 4 mini to boot automatically when power is restored. Is it possible that the code 0x03 is assigned for both the scenarios? Is there a way to distinguish them?
Thanks.
Posted : 17/04/2024 2:59 am
The current firmware does not set the register #11 (I2C_ACTION_REASON) for startup due to power connection/restoring. So in such case the register keeps the value that prevously set.
We will add one more reason code for this scenario in next revision of firmware. Meanwhile if you want to do so by yourself, you may put
updateRegister(I2C_ACTION_REASON, 9 /*or any unused number you prefer*/);
above this line.
Posted : 17/04/2024 8:18 am
The new values for register #11 has been added in firmware reversion 6.
Posted : 18/06/2024 3:01 pm
