[Solved / Archived] WittyPi L3V7 won't power on
(@drunkenungulate)
Background:
I have been trying to get scripted scheduling working with a couple of new WittyPi 4 L3V7 on a Raspi 4 running Debian Bookworm.
Using a schedule.wpi like this:
BEGIN 2024-06-11 12:20:00
END   2024-06-11 12:35:00
ON    M10
OFF   M5
 runScript.sh output showed the single shutdown and startup times I expected:
> wittypi/runScript.sh
--------------- 2024-06-11 12:16:57 ---------------
Schedule next shutdown at: 2024-06-11 12:30:00
Schedule next startup at:  2024-06-11 12:35:00
The shutdown happened as expected, but then it immediately started up again. This was in the log:
[xxxx-xx-xx xx:xx:xx] System: Debian GNU/Linux 12 (bookworm), Kernel: Linux 6.6.31+rpt-rpi-v8, Architecture: arm64
[xxxx-xx-xx xx:xx:xx] RTC offset register has value 0x79
[2024-06-11 12:30:28] Done :-)
[2024-06-11 12:30:28] Firmware ID: 0x37
[2024-06-11 12:30:28] Firmware Revison: 0x04
[2024-06-11 12:30:28] Current Vout=5.21V, Iout=1.26A
[2024-06-11 12:30:28] System starts up because of the scheduled startup got delayed.
[2024-06-11 12:30:28] Maybe the scheduled startup was due when Pi was running, or Pi had been shut down but TXD stayed HIGH to prevent the power cut.
[2024-06-11 12:30:33] Send out the SYS_UP signal via GPIO-17 pin.
[2024-06-11 12:30:33] Schedule script is interrupted, revising the schedule...
[2024-06-11 12:30:33] Pending for incoming shutdown command...
This is what I was seeing consistently. If I cleared the scripted schedule and both input times and put in only a shutdown time it behaved like I expected. Based on the symptoms I found this post, which suggested a firmware <=5 may have a fix. The two boards I just got from Digikey last week are both 0x04. I followed the flashing instructions, using a fresh Debian Bullseye image to flash it from the pi GPIO. The output matched what the steps showed at each step, but when I moved it back to the original Raspi, it wouldn't power on.
Current Symptom:
After flashing from 0x04 to 0x06, I mounted the WittyPi4 L3V7 on a Raspi 4. Connected an official Raspi 3A power supply to the WittyPi. There is a solid green LED and flashing blue LED. Pressing the power button does nothing. Connecting a battery changes the blue to steady on, but still no change from the power button.
Disconnected power. Unmounted the WittyPi from the GPIO header, powered it and tried again. The symptoms are the same. Solid green, flashing or solid blue. No white or red LED. Power button changes nothing.
I put my second WittyPi on the Raspi, connected power and battery and it works like I expect.
Did I brick this? Any ideas?    Thanks!
Posted : 11/06/2024 9:04 pm
It seems the firmware was not properly flashed into the device.
Have you read this? https://www.uugear.com/portfolio/compile-flash-firmware-for-witty-pi-4/
Maybe you followed the old instructions and the new firmware didn't get flashed properly. The link above is the new one.
Posted : 11/06/2024 10:15 pm
(@drunkenungulate)
Yes, that's the procedure I used. Guess I'll try to flash it again.
Posted : 12/06/2024 3:04 pm
(@drunkenungulate)
Same result.  Here's the verify step:
$ sudo avrdude -p attiny841 -C ~/avrdude_gpio.conf -c RasPi -v
avrdude: Version 6.3-20171130
         Copyright (c) 2000-2005 Brian Dean,  http://www.bdmicro.com/
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "/home/jeff/avrdude_gpio.conf"
         User configuration file is "/root/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : unknown
         Using Programmer              : RasPi
         AVR Part                      : ATtiny841
         Chip Erase delay              : 4500 us
         PAGEL                         : P00
         BS2                           : P00
         RESET disposition             : possible i/o
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65     6     4    0 no        512    4      0  4000  4500 0xff 0xff
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           flash         65     6    16    0 yes      8192   16    512  4500  4500 0xff 0xff
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
         Programmer Type : linuxgpio
         Description     : Use the Linux sysfs interface to bitbang GPIO lines
         Pin assignment  : /sys/class/gpio/gpio{n}
           RESET   =  12
           SCK     =  24
           MOSI    =  23
           MISO    =  18
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e9315 (probably t841)
avrdude: safemode: lfuse reads as E2
avrdude: safemode: hfuse reads as DD
avrdude: safemode: efuse reads as F5
avrdude: safemode: Fuses OK (E:F5, H:DD, L:E2)
avrdude done.  Thank you.
Here's flashing:
$ sudo avrdude -p attiny841 -C ~/avrdude_gpio.conf -v -c RasPi -e -Uefuse:w:0xF5:m -Uhfuse:w:0xDD:m -Ulfuse:w:0xE2:m -Uflash:w:./WittyPi4_L3V7.ino.hex:i
         PAGEL                         : P00
         BS2                           : P00
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
           RESET   =  12
           SCK     =  24
           MOSI    =  23
           MISO    =  18
avrdude: erasing chip
avrdude: reading input file "0xF5"
avrdude: writing efuse (1 bytes):
Writing | ################################################## | 100% 0.00s
avrdude: 1 bytes of efuse written
avrdude: verifying efuse memory against 0xF5:
avrdude: load data efuse data from input file 0xF5:
avrdude: input file 0xF5 contains 1 bytes
avrdude: reading on-chip efuse data:
avrdude: verifying ...
avrdude: 1 bytes of efuse verified
avrdude: reading input file "0xDD"
avrdude: writing hfuse (1 bytes):
avrdude: 1 bytes of hfuse written
avrdude: verifying hfuse memory against 0xDD:
avrdude: load data hfuse data from input file 0xDD:
avrdude: input file 0xDD contains 1 bytes
avrdude: reading on-chip hfuse data:
avrdude: 1 bytes of hfuse verified
avrdude: reading input file "0xE2"
avrdude: writing lfuse (1 bytes):
avrdude: 1 bytes of lfuse written
avrdude: verifying lfuse memory against 0xE2:
avrdude: load data lfuse data from input file 0xE2:
avrdude: input file 0xE2 contains 1 bytes
avrdude: reading on-chip lfuse data:
avrdude: 1 bytes of lfuse verified
avrdude: reading input file "./WittyPi4_L3V7.ino.hex"
avrdude: invalid record at line 1506 of "./WittyPi4_L3V7.ino.hex"
avrdude: read from file './WittyPi4_L3V7.ino.hex' failed
After complete I shut down the pi and then connected only power to the WittyPi. Green LED solid, blue flashing. Pressing the power button does nothing.
Posted : 12/06/2024 3:47 pm
@drunkenungulate I think your firmware file is not correct:
 The proper way to save the firmware file to your local disk, is to right click the link and choose “Save Link As…” in the pop-up menu, and save the .hex file into the directory you choose, as mentioned in the tutorial.
Posted : 12/06/2024 4:01 pm
(@drunkenungulate)
Yep, thanks for your help. I had found the latest firmware on github earlier and had right-click, save as downloaded it already. But that got me github html and not the raw file. Didn't realize that while I was looking at the tutorial later. In my defense I did at least look for a checksum to verify the download.
It might be good to post SHA256 sums for the compiled files, both for download integrity verification and to help defend users against their own inattention/stupidity.
In any case it's working now. Thanks again!
Posted : 12/06/2024 5:14 pm
@drunkenungulate as mentioned in the forum rules, one topic is for one main question only. I have moved your new post to: https://www.uugear.com/forums/technial-support-discussion/witty-pi-cuts-power-during-the-reboot/#post-962
Posted : 13/06/2024 8:29 am
