[Mark Solved / Archieved] Zero2go software compatibility with RPI 5?
(@tomi-hakala)
I have RPI 5 2Gb model with Zero2go hat, system is powered with 12v Lifepo4 battery and it is all working very well. However I tried installing zero2go software and after that system does not start anymore. I have double checked that 1-wire inteface is disabled, so I am not quite sure if system boot issue is caused by RPI getting a shutdown signal through 1-wire interface or not.
Is there any known issues which would prevent zero2go software from working on RPI 5 running Debian 12?
$ uname -a
Linux portable 6.6.74+rpt-rpi-2712 #1 SMP PREEMPT Debian 1:6.6.74-1+rpt1 (2025-01-27) aarch64 GNU/Linux
$ lsmod
Module                  Size  Used by
xt_MASQUERADE          49152  2
xt_tcpudp              49152  0
xt_mark                49152  2
nft_compat             49152  4
nft_chain_nat          49152  2
nf_nat                 98304  2 nft_chain_nat,xt_MASQUERADE
nf_conntrack          180224  2 nf_nat,xt_MASQUERADE
nf_defrag_ipv6         49152  1 nf_conntrack
nf_defrag_ipv4         49152  1 nf_conntrack
cdc_ether              49152  0
tun                    98304  2
nf_tables             294912  99 nft_compat,nft_chain_nat
nfnetlink              49152  2 nft_compat,nf_tables
rfkill                 49152  1
binfmt_misc            49152  1
sr_mod                 49152  0
cdrom                  65536  1 sr_mod
spidev                 49152  0
vc4                   409600  0
snd_soc_hdmi_codec     49152  0
drm_display_helper     49152  1 vc4
cec                    65536  1 vc4
drm_dma_helper         49152  1 vc4
drm_kms_helper        245760  2 drm_dma_helper,vc4
snd_usb_audio         327680  0
aes_ce_blk             49152  0
aes_ce_cipher          49152  1 aes_ce_blk
ghash_ce               49152  0
rpivid_hevc            65536  0
snd_soc_core          311296  2 vc4,snd_soc_hdmi_codec
gf128mul               49152  1 ghash_ce
snd_hwdep              49152  1 snd_usb_audio
libaes                 49152  3 aes_ce_cipher,ghash_ce,aes_ce_blk
snd_usbmidi_lib        49152  1 snd_usb_audio
snd_rawmidi            65536  1 snd_usbmidi_lib
pisp_be                49152  0
snd_compress           49152  1 snd_soc_core
v4l2_mem2mem           65536  1 rpivid_hevc
snd_seq_device         49152  1 snd_rawmidi
sha2_ce                49152  0
sha256_arm64           49152  1 sha2_ce
snd_pcm_dmaengine      49152  1 snd_soc_core
sha1_ce                49152  0
videobuf2_dma_contig    49152  2 pisp_be,rpivid_hevc
snd_pcm               147456  5 snd_usb_audio,snd_soc_hdmi_codec,snd_compress,snd_soc_core,snd_pcm_dmaengine
videobuf2_memops       49152  1 videobuf2_dma_contig
videobuf2_v4l2         49152  3 pisp_be,rpivid_hevc,v4l2_mem2mem
snd_timer              65536  1 snd_pcm
videodev              344064  4 pisp_be,videobuf2_v4l2,rpivid_hevc,v4l2_mem2mem
snd                   131072  10 snd_seq_device,snd_hwdep,snd_usb_audio,snd_usbmidi_lib,snd_soc_hdmi_codec,snd_timer,snd_compress,snd_soc_core,snd_pcm,snd_rawmidi
raspberrypi_hwmon      49152  0
videobuf2_common       98304  6 pisp_be,videobuf2_dma_contig,videobuf2_v4l2,rpivid_hevc,v4l2_mem2mem,videobuf2_memops
mc                     81920  7 videodev,snd_usb_audio,pisp_be,videobuf2_v4l2,videobuf2_common,rpivid_hevc,v4l2_mem2mem
spi_bcm2835            49152  0
gpio_keys              49152  0
cn                     49152  1 wire
rp1_pio                65536  0
i2c_designware_platform    49152  0
rp1                    49152  1 rp1_pio
i2c_designware_core    49152  1 i2c_designware_platform
nvmem_rmem             49152  0
raspberrypi_gpiomem    49152  0
rp1_mailbox            49152  1
rp1_adc                49152  0
sg                     65536  0
i2c_dev                49152  0
drm                   688128  4 drm_kms_helper,drm_dma_helper,vc4,drm_display_helper
fuse                  147456  1
drm_panel_orientation_quirks    65536  1 drm
backlight              49152  2 drm_kms_helper,drm
dm_mod                163840  0
ip_tables              65536  0
x_tables               81920  5 nft_compat,xt_tcpudp,ip_tables,xt_MASQUERADE,xt_mark
ipv6                  589824  48
uio_pdrv_genirq        49152  0
uio                    49152  1 uio_pdrv_genirq
Posted : 10/03/2025 9:44 am
Our record shows that the latest version of Zero2Go Omini software is V1.60, which was out about 11 months ago.
That means it should be using wiringPi V3.12.
Please pay attention to the messages printed on the screen during the installation, and see if there is any error during wiringPi installation.
Incorrectly installed wiringPi may cause the system automaticall shutdown after startup. If it is the case, there is a workaround to make the SD card bootable again (but still you will need to make correct installation of software again, to make Zero2Go Omini work).
Posted : 10/03/2025 11:31 am
